Assemble function templale callable in C51
Hi All
Here is my template to create quickly a function in assemlbe and call in C51
Enjoy
; Template of a function writen in assembly then call by C51 compiler
; Created by Huynh Vinh Ha - Vietnam, date 11/09/2004
; declare fname in C51: extern unsigned char fname(unsigned char x,char y)
; replace fname with actual name of your function
; replace MAIN with actual name of main program which call you function
; Input 1st parameter put in R7, 2nd in R5, 3rd R3 ( R7/R6 for int var)
; Return value
;bit : carry flag
;char R7
;int R6.R7
;long R4..R6
;float R4..R6
;pointer R1..R3
?PR?_fname?MAIN SEGMENT CODE ; code location
?DT?_fname?MAIN SEGMENT DATA OVERLAYABLE ; data segment
PUBLIC _fname ; public name
RSEG ?DT?_fname?MAIN
?_fname?BYTE: ; declare local variables used in this function
x?040: DS 1 ; byte type variable
z?041: DS 1 ; byte
clk bit 90H.0 ; bit type var
RSEG ?PR?_fname?MAIN
_fname: ; begin function
USING 0
; MOV x?040,R7 ; get parameter to local variable x
; ------ do something
; ACALL DELAY ; call internal subroutine if present
; MOV R7,return_value ;
RET
; internal subroutine inside, for example
;DELAY: NOP
; RET
END ; END OF _fname
  • This template makes various assumptions, and will only work for the specific return type & parameters shown.
    A far better approach is just to create a "dummy" 'C' function with the required return type, parameters, etc, and then compile it using the SRC directive.
    That way, you're guaranteed to get the correct result!
