Hi, I'm trying to get some of the example programs running on my SK-167CS board, but I'm finding that the hex files that uVision2 generates does not work correctly. Running the examples via the uVision2 debugger works correctly, but not when I load up the generated hex file (using PHYTEC FlashTools 16W). It seems that global variables in the code are not being accessed properly. For example: #include <reg167.h> int num = 0; void serialout(int a); /* code to send 'a' to the RS232 port */ void main() { while(1) { serialout(num); num++; } } The above code *should* have "12345..." printed out to the port (seen using a terminal program) but instead I get some rubbish like "q535q535q535...". Now, if the variable 'num' was a local variable inside main(), then it produces the correct output. Is there something I'm missing? (I'm very new to microcontroller programming so I'm pretty sure there's a big chunk of something missing :) TIA
