how to avoid the switch code
I have the impression that the routine that process a switch statement is (justifiably?) complicated and slow.
I have a case with a lot of case statements.
To "help the compiler" the cases are 0, 2, 4... to allow the use of JMP @a+dptr.
I can see a way of going to a51 for the switch and then back to c for the code, but that would be almost unreadable.
Has anyone found a fast and readable way to do something like this?
  • I have the impression that the routine that process a switch statement is (justifiably?) complicated and slow.
    There are three different ways the compiler generates switch/case blocks. The method used depends on the number and structure of the cases.
    The compiler only uses a library routine when it cannot determine the structure of the case values.
    Refer to http://www.keil.com/support/docs/1316.htm for more detail on how to get the compiler to generate a jump table.
    Jon
    Jon
