I2C Read Problem
I am trying to write a Set of Bit Bang I2C Functions to communicate with a SRF08 Range Finder. I found some code by Grant Beattie for the HC11 and have addapted it for the 89LPC932. Now I have the Start, stop, and Write Byte functions working, but the Read function is not working. I have the suggested pull-up resistors and when I run the code the value outputs 255 meaning the data line never falls. This is my code please help.
unsigned char I2cRead(unsigned char count)
unsigned char mask;
unsigned char value;
unsigned char index = 0;
while(count)
   mask  = 0x80;
   value = 0x00;
   while(mask)      // Do the 8 data bits...
      SclHi();       // Set SCL
                  //and wait for it to go hi.
     I2cDelay();
      if( GetSda() ) // Read the bit
         value |= mask; // the returned byte.
      SclLo();  // Bring SCL low again
      I2cDelay();
      mask >>= 1;
  Readvalue = value;   // Save the read byte.
   index++;
   count--;
   if(count) // If not the last byte, ACK
      SdaLo();      // Bring SDA low for ACK.
      SclHi();      // Clock high.
      I2cDelay();
      SclLo();      // Clock low.
      SdaHi();      // Release SDA.
      I2cDelay();
SdaHi();   // SDA high for NACK on last byte.
I2cDelay();
I2cDelay();
return 0;
