I am new to XC164 and to PWM. I am trying to control some DC motors. Does anybody has any software examples on how to implement PWMs on CAPCOM1/2 and CAPCOM6 on XC164 micro? Also, does anybody know how many simple and independent PWMs can be implemented using XC164 micro? Thank you, Oliver
Take a look to the Infineon web side. I think that have some application notes there.
try to configure the pwm-module by using Dave. That helped me a lot. ...Leo
To Oliviu Condurache Hi Oliviu I have the same problem. I need 4 indipendent PWMs using XC164. If you have a solution, please contact me. Thanks Paolo automazione@geco-group.it
void vInitCoilsAndDigitalOutputs( void ) /******************************************************************************* Description: This routine initializes the CAPCOM units. The PWM output channels (CC0IO-CC7IO) are initialized to operate in mode 3. The DC channels (CC16IO-CC23IO) are initialized to operate in mode 2, this allows port 8 outputs to be controlled as digital outputs rather than frequency outputs. Inputs: NONE Outputs: NONE Globals: *******************************************************************************/ { /* Setup the port bits*/ /* Make the outputs for drivers 0 through 5 outputs (6&7 should be inputs). Don't mess with the other bits. Make sure they are in push/pull mode. Don't mess with those other bits either. A one in DP2 makes that bit an output. A zero in ODP2 makes that bit push/pull.*/ DP2 |= 0x0003F; ODP2 &= 0x0FF00; /* Make the outputs for drivers 16 through 23 outputs. Make sure they are in push/pull mode. A one in DP8 makes that bit an output. A zero in ODP8 makes that bit push/pull. These are only 8 bit registers, so we don't have to worry about the other bits. (Also config port 7.4 which is the neutral relay). */ DP8 = 0x000FF; ODP8 = 0x00000; P8 = 0x007F; /* Turn all digital outputs off EXCEPT CC23IO (ISO_PWR_ENA) */ m_bitPort7_4_DIR = 1; m_bitPort7_4_TYP = 0; m_bitPort7_4 = 1; /* Make sure neutral relay is off */ /* Initialize the timers*/ /* Timer reload register values*/ T0REL = T7REL = COIL_RELOAD; /* Set the timer input selection All timers are driven from the CPU clock*/ m_bitT0I0 = m_bitT0I1 = m_bitT0I2 = 0; m_bitT7I0 = m_bitT7I1 = m_bitT7I2 = 0; /* Both timers are in timer mode*/ T0M = T7M = 0; /* Initialize the PWM output channels (CC0IO-CC7IO)*/ CCM0 = CCM1 = CCMX_INIT_PWM_OUTPUTS; /* Initialize the DC output channels (CC16IO-CC23IO, CC28IO)*/ CCM4 = CCM5 = CCMX_INIT_DC_OUTPUTS; CCM7 |= INIT_DC_OUPUT; /* Set all the output values to off*/ CC0 = CC1 = CC2 = CC3 = CC4 = CC5 = CC6 = CC7 = COIL_OFF; CC16 = CC17 = CC18 = CC19 = CC20 = CC21 = CC22 = CC23 = CC28 = COIL_OFF; /* Enable the timers*/ T0R = T7R = 1; }/* vInitCoilsAndDigitalOutputs() */
/* This defines the timer reload value. The actual value is based on the selected resolution. The maximum valve coil value is also set up here. Passing a value greater than MAX_COIL_VAL to the valve coil driver output functions will generate a runtime error.*/ #define COIL_RELOAD 0x0FC00 /* 2.441 KHz output frequency*/ #define MAX_COIL_VAL 0x003FE #define OFFSET_VAL 48 /* The PWM outputs are controlled by CAPCOM channels 0 through 7. This word is programmed into registers CCM0 and CCM1 so that these channels operate in compare mode 3 and are allocated to timers T0 and T7.*/ #define CCMX_INIT_PWM_OUTPUTS 0x07777; /* The DC outputs are controlled by CAPCOM channels 16 through 23. This word is programmed into registers CCM4 and CCM5 so that these channels operate in compare mode 2 and are allocated to timers T0 and T7. In compare mode 2, the output pin is unaffected by an interrupt and therefor the output can be used as a dc output.*/ #define CCMX_INIT_DC_OUTPUTS 0x06666; #define INIT_DC_OUPUT 0x06;
