Packing Bytes
The literature I'm reading suggests that I can specify the number of bits a certain data type must occupy, and that I can possibly store several of these packed variables into the same byte for reduced storage space.
typedef struct{
unsigned int a: 4;
unsigned char b: 2;
} my_type;
I tried the above but it just truncates the values assigned and stores them in separate two byte wide and 1 byte wide spaces respectively. What's the trick?
Regards,
Murray R. Van Luyn.
