Hi, The literature I'm reading suggests that I can specify the number of bits a certain data type must occupy, and that I can possibly store several of these packed variables into the same byte for reduced storage space. typedef struct{ unsigned int a: 4; unsigned char b: 2; } my_type; I tried the above but it just truncates the values assigned and stores them in separate two byte wide and 1 byte wide spaces respectively. What's the trick? Regards, Murray R. Van Luyn.
What's the trick? The trick? Try to learn your profession before doing it. The hack-and-slash technique might have worked when learning the chimp-designed deep fryers when you were at McDonald's, but not so well as an embedded programmer. Please read the manual. Oh yeah... and avoid jokes that throw back to a time of hardship for the entire civilized world to get a cheap laugh based on the ethnicity of a company name. For those of you following along at home: This gentlemen posted the same question in another forum where he referred to the compiler as "Siege Heil C" (his spelling).
The problem is that you've changed sizes of the integers into which the bit fields are supposed to be packed; the first is an int, and the second a char. This tells the compiler that you really do want two different integers, 2 bytes and 1 byte respectively. Try
typedef struct { unsigned int a: 4; unsigned int b: 2; } my_type;
Thanks Drew. That's answered a few questions. Regards, Murray R. Van Luyn.
