Hi All, I have implemented a linked list in my program on infineon sle66c168PE. at very first time i intialize the starting node with the null value and whenever i need to add the node to the linked list the malloc function return me the value 0x0000 that is a null value.which causes the program to fail. can anyone please suggest me something to work-around this problem... its very urgent ...Plz Thanks and Regards, Ankit
Did you call init_mempool to setup the heap? Jon
yes i have used init_mempool to setup heap. i know its not feasable to use malloc in an embedded application but i know that my link list may contain 30 elements of 4 bytes each at max and i have enough RAM to accomodate all this. but the thing is even if i try to add the very first node still it returns null. this thing i could not understand and was thinking about this problem all night. Please suggest.... -Ankit
Is your heap large enough? Can you post a small example that can be compiled and that runs that shows the problem? Jon
