When I build the following program,I get a warning. *** WARNING L15: MULTIPLE CALL TO SEGMENT SEGMENT: ?PR?FUNC?H CALLER1: ?PR?TASK1?H CALLER2: ?PR?TASK2?H The configuration of RTX51-Tiny is, ; Define Round-Robin Timeout in Hardware-Timer ticks. TIMESHARING EQU 0 ; default is 5 Hardware-Timer ticks. ; ; 0 disables Round-Robin Task Switching ; Will my program run correctly? How can I remove the warning? Thanks. hylnew@tom.com
//////////////////////////////////////////////////////////// //filename: h.c #include <rtx51tny.h> // unsigned char func(bit d) { if(d)return (0); else return (1); } // void init(void) _task_ 0 { os_create_task(1); os_create_task(2); os_delete_task(0); } // void task1(void) _task_ 1 { while(1){ os_wait(K_TMO,10,0); func(0); } } // void task2(void) _task_ 2 { while(1){ os_wait(K_TMO,10,0); func(1); } } ////////////////////////////////////////////////////////////
