I have spent a lot of time on this. Here is my observation: I am porting a piece of GNU code to the MCB2130 card using the Keil toolset (including the limited compiler that comes with the board). I have a function call: handle = function1(a, b, c, d); handle is unsigned char. function1 has a number of different return codes. When I look at the generated code for one specific return code, I see the following: 923: return (-20); 00000024 4800 LDR R0,=0xFFFFFFEC 00000026 E0EC B L_204 ; T=0x00000202 924: } So far so good.... but when I get to label L_204, I see the following: 0000022A L_204: 0000022A 4886 LDR R0,=0x218 0000022C 4485 ADD R13,R13,R0 0000022E B001 ADD R13,#0x4 00000230 BC08 POP {R3} 00000232 4718 BX R3 00000234 ENDP ; Obviously, the first thing that this code does is to overwitre the return code. My handle is assigned a wrong value. I found out that if I remove some code inside function1, especially a call to another function, the L_204 code does not overwrite the return code (obvisouly function1 is now broken). I am going to try the GNU compiler. Any idea ?
