Hi all I write a sample code like a = 1 << b; when b = 0 , The result for a will get 2 If I uncheck "Enable ANSI integer promotion rules " ,It will get correct answer 1 can anyone tell me why ?? Thanks a lot
Sorry, I try this again It seems like even I uncheck "Enable ANSI integer promotion rules " The result also fail. Here is the code ,Please help to this void start_dmpg(void) { uchar b = ptr_reg[PCIC_PC2MPU_CMD7]; uchar a = (ENABLE << b); } ; FUNCTION start_dmpg (BEGIN) ; SOURCE LINE # 169 ; SOURCE LINE # 170 ; SOURCE LINE # 175 0000 900000 E MOV DPTR,#ptr_reg 0003 E0 MOVX A,@DPTR 0004 FE MOV R6,A 0005 A3 INC DPTR 0006 E0 MOVX A,@DPTR 0007 FF MOV R7,A 0008 8F82 MOV DPL,R7 000A 8E83 MOV DPH,R6 000C E582 MOV A,DPL 000E 2447 ADD A,#047H 0010 F582 MOV DPL,A 0012 E583 MOV A,DPH 0014 3404 ADDC A,#04H 0016 F583 MOV DPH,A 0018 E0 MOVX A,@DPTR 0019 FF MOV R7,A 001A 900000 R MOV DPTR,#b 001D EF MOV A,R7 001E F0 MOVX @DPTR,A ; SOURCE LINE # 177 001F 900000 R MOV DPTR,#b 0022 E0 MOVX A,@DPTR 0023 FF MOV R7,A 0024 7401 MOV A,#01H 0026 A807 MOV R0,AR7 0028 08 INC R0 0029 8002 SJMP ?C0181 002B ?C0180: 002B C3 CLR C 002C 33 RLC A 002D ?C0181: 002D D8FC DJNZ R0,?C0180 002F FF MOV R7,A 0030 900000 R MOV DPTR,#a 0033 EF MOV A,R7 0034 F0 MOVX @DPTR,A C51 COMPILER V7.08 CMD51 05/10/2005 14:34:41 PAGE 106 ; SOURCE LINE # 199 0035 ?C0012: 0035 22 RET ; FUNCTION start_dmpg (END)
"b" is a variable, extracted from a table. Are you sure it is zero when you execute the shift?
Yes,I Sure The ptr_reg[PCIC_PC2MPU_CMD7] Value is set by me,I have print out the value is zero like I set,but the answer is 2. Thanks for yuor replay.
Hi Noone know this ?? why a = 1 << b when b = 0 , a is not always equal 1 why??
"Noone know this ??" I don't think anyone is convinced that b=0. Try compiling a simple test case in isolation, if it gives the correct result take another look at 'b' to see whether it is actually 1.
The section of your code that does the shifting is this bit:
Thanks for replay I have a ready to this ,Please see it #define ENABLE 1 uchar volatile xdata *ptr_reg=0x8000; bug0 =0; bug1 =0; uchar b = pre_reg[0]; a = (ENABLE << b); if ( b != 0 ) bug0++; if ( a != 1 ) bug1++; after I run this ,bug0 is zero ,but bug1 is nonzero. I also have run this code in VC60,and it work fine. Thanks for your kind help
Thank to Graham I also think the asm code is fine, but I realy got a wrong answer >< maybe I have setting something wrong。 For now,I just use switch-case to do this sample work.
Thanks for correct my type error^^""" Sorry,I have already delete the code so i just type it again. It is ptr_reg not pre_reg。 Thanks a lot
Do you call the function from an interrupt service routine. The code that you have posted works correct for registerbank 0, but will fail if you call it from an interrupt service routine that uses a different register bank. See also: http://www.keil.com/support/docs/2201.htm Reinhard
