Hi all, I am working with Infineon XC866 controller. I am measuring the number of cycles consumed by the keil built in libraries. To optimize the speed i am selecting Favour speed in the project settings.I have selected the level of optimization as 9.I could not find any improvement in the cycles. Further there is no improvement in the code size if i give Favour size in the project settings. Whether anyother settings should be taken care to generate an optimised code by the compiler? Please help me out Thanks in advance Chris
I am measuring the number of cycles consumed by the keil built in libraries. To optimize the speed i am selecting Favour speed in the project settings.I have selected the level of optimization as 9.I could not find any improvement in the cycles. congratulations Keil! If the optimizer can not optimize the code is already optimal. Erik
I guess you want the most compact code possible. The following link describes these options: http://www.keil.com/support/docs/2297.htm Reinhard
"The following link describes these options: http://www.keil.com/support/docs/2297.htm" But do those options have any effect on pre-built library code?
