issues in ISD51 debugging
Hello all,
I have a problem using ISD51 to debug my board with C515C processor. In order to test the serial port and basic ISD51 functionality, I used a small piece of code below (Test.c).
First under the Keil PK51 software simulator, it works fine. I could use the Hyperterminal to receive or to send any character to my board. Then I switched from simulator to Keil In-System ISD51 Debug and it failed. I don't know why as I tried everything in Keil's online documentation.
One thing I need to point out is that I didn't burn the code into flash and instead used a flash simulator Flex III.
Can someone giveme a hand with this issue?
Thanks in advance,
Frank
TEST.C: ISD51 Demo for Infineon C868
Copyright 2003 Keil Software, Inc.
#include <intrins.h>
#include <stdio.h>
#include "ISD51.h"
#include "reg515a.h"
/* parameters to initialize serial communication */
#define B_38400 0x05 /* 38400 baud */
#define B_19200 0x04 /* 19200 baud */
#define B_9600 0x03 /* 9600 baud */
#define B_4800 0x02 /* 4800 baud */
#define B_2400 0x01 /* 2400 baud */
#define B_1200 0x00 /* 1200 baud */
void Delay(unsigned int i) {
unsigned int j;
while(i--) { // delay
WDT = 1; // reset
SWDT = 1;
j = 0x200;
while (j--);
void Project_Init(serBaud) {
switch ( serBaud )
{ /* oscillator frequency = 10 Mhz */
case B_38400:
SRELH = 0x03; /* Reloadwert für 38400 Baud */
SRELL = 0xF0;
PCON |= 0x80; /* SMOD = 1 */
break;
case B_19200:
SRELH = 0x03; /* Reloadwert für 19200 Baud */
SRELL = 0xDF;
break;
case B_9600:
SRELH = 0x03; /* Reloadwert für 9600 Baud */
SRELL = 0xBF;
break;
case B_4800:
SRELH = 0x03; /* Reloadwert für 4800 Baud */
SRELL = 0x7E;
break;
case B_2400:
SRELH = 0x02; /* Reloadwert für 2400 Baud */
SRELL = 0xFC;
break;
case B_1200:
SRELH = 0x01; /* Reloadwert für 1200 Baud */
SRELL = 0xF7;
break;
default:
return;
break;
ADCON0 |= 0x80; /* enable baud rate generator */
SCON = 0x50; /* mode 1: 8-bit UART, enable receiver */
// ES = 1; /* enable serial interrupt IE.ES */
#if 1 // uncomment this function to verify serial communication
* Test Function: verify serial communication with HyperTerminal
void TestSerial (void) {
char c = 'A';
TI = 1;
while (1) {
Delay(200);
if (RI) {
c = SBUF;
RI = 0;
while (!TI);
TI = 0;
SBUF = c;
#endif
void main (void) {
unsigned int i;
Project_Init(B_9600); // Initialize Chip and Serial Interface
#ifndef ISD51 // init ISD51 only when the uVision2 Debugger tries to connect
TestSerial();
#endif
#if 0 // init ISD51 and start user program until the uVision2 Debugger connects
ISDinit (); // initialize uVision2 Debugger and continue program run
#endif
#if 0 // init ISD51 and wait until the uVision2 Debugger connects
ISDwait (); // wait for connection to uVision2 Debugger
#endif
while (1) {
#ifdef ISD51 // init ISD51 only when the uVision2 Debugger tries to connect
ISDcheck(); // initialize uVision2 Debugger and continue program run
#endif
i++;
  • More info...
    The info displayed on the error message window as below:
    ISD51 Monitor Error
    There was a wrong reply from the target system
    Please check the following items:
    - Review the initialization of the serial interface (baudrate)
    - Make sure the loaded application matches the ROM content
    I copied a wrong code last time. Please check the code below.
    #include <stdio.h>
    #include "ISD51.h"
    unsigned int j;
    WDT = 1; // reset
    SWDT = 1;
    j = 0x200;
    while (j--);
    switch ( serBaud )
    case B_38400:
    SRELL = 0xF0;
    break;
    case B_19200:
    SRELL = 0xDF;
    break;
    case B_9600:
    SRELL = 0xBF;
    break;
    case B_4800:
    SRELL = 0x7E;
    break;
    case B_2400:
    SRELL = 0xFC;
    break;
    case B_1200:
    SRELL = 0xF7;
    break;
    default:
    return;
    break;
    char c = 'A';
    TI = 1;
    while (1) {
    Delay(200);
    if (RI) {
    c = SBUF;
    RI = 0;
    while (!TI);
    TI = 0;
    SBUF = c;
    #endif
    void main (void) {
    unsigned int i;
    TestSerial();
    #endif
    #ifdef ISD51 // init ISD51 and start user program until the uVision2 Debugger connects
    #endif
    #endif
    while (1) {
    Delay(200);
    #endif
    i++;
Reply Children
