MSC1210, IRQ on serial port 0 and 1
Hi all,
I need a configuration advice for the use of both serial 0 and 1, before I start coding.
I need to know if I should use IRQ on on both serial ports, or polling is adequate in our application.
In our application, we will use the serial0 for configuration such as set this variable or upload configuration file, etc.. On the serial1, we will run a slave MODBUS protocol, half-duplex, RS485. Both ports will not run simultaneously, meaning that if a user on serial0 is configuring the MSC1210, then serial1 will be disabled for the time been.
Also, when the MODBUS is active, there will be data been sampled and scaled at about 1 sample per second.
Also, if someone has MODBUS slave available for sale, please contact me.
Best regards
Michel Belanger
SEIDEL inc.
