Hi all, I have an evaluation version running V2.31 with following stuff... V51.exe V7.01 OH51.exe V2.6 BL51.exe V5.01 EACH TIME I a load an older (working) project and recompile it without ANY changes ... The Hex file is incorrect. I need to RECOMPILE ALL before it works... It is possible to repeat the failure! Anyone with the same problem? Any solution? Kind Regards
You'll really have to be a good deal more specific than this before it becomes a sensible project for anyone else to look into it: What does "older" project actually mean? How old is it, and what uV version was it made with originally? What exactly does "the hex file is incorrect" mean to you? And even if the failure is for real, why do you consider a "rebuild all", once, an inappropriate burden to fix it?
Assume you have two projects A & B Load project A. Compile -> failure using the HEX file in the controller. Recompile A -> Hex is working in target Load project B. Compile -> failure using the HEX file in the controller. Recompile B -> Hex is working in target Load project A. in a file type a "space" anywhere to modify the file. (no code changes!) Compile -> failure using the HEX file Recompile B -> Hex is working fine. and so on .... This can be repeated over and over .....
The Hex file is incorrect. how, what, details, please Erik
