//////////////////////////////////////////////////////////////////////////////// //Author: Linh Tran //This program will create a square matrix A (given). Based on this matrix, the //program will find a square matrix B, which has same size as A. The values of //B will be found based on values from A, such as: //- B(i,i) = 0 // - if i < j then B(i,j) = max {A(k,m) | where k <= i and m >= j} // - if i > j then B(i,j) = max {A(k,m) | where k >= i and m <= j} //In this program, i suppose that the size of matries is 5x5. //This program takes NxN running times. //It takes me 40 minutes to creat this program. /////////////////////////////////////////////////////////////////////////////// #include <iostream> #include <cstdlib> #include <iomanip> using std::cout; using std::endl; #ifndef SQUAMATRIX5_H #define SQUAMATRIX5_H /////////////////////////////////////////////////// ////Begining of class /////////////////////////////////////////////////// class SquaMatrix{ public: SquaMatrix(int row =0, int col=0); //constructor int Max1(int, int); //find max value of A when in B has row > colume int Max2(int, int); //find max value of A when in B has row > colume void Print(); //print result void Compute(); //find matrix B bases on A void Generate(); //generate given matrix A int i ; //holding index of matries int j ; int B[10][10],A[10][10]; int temp; //temporary holding value of matrix A }; #endif /////////////////////////////////////////////////////////// //////constructor to initialize the size of matries /////////////////////////////////////////////////////////// SquaMatrix::SquaMatrix(int row, int col){ i = row; j = col; temp = 0; } ////////////////////////////////////////////////////////// ////Generate the given matrix A ////////////////////////////////////////////////////////// void SquaMatrix::Generate(){ for(int a = 0; a < i; a++){ for(int b =0; b< j; b++){ A[a][b]= 1+rand() % 4; //generate value of matrix from 1 to 4 } } } //////////////////////////////////////////////////////////// ////////find matrix B based on matrix A //////////////////////////////////////////////////////////// void SquaMatrix::Compute(){ for (int i_B = 0; i_B < i; i_B++){ for (int j_B =0; j_B <j; j_B++){ if (i_B == j_B ){ B[i_B][j_B] = 0; } else{ if( i_B < j_B ){ B[i_B][j_B] = Max1(i_B,j_B); } else{ if( i_B > j_B ){ B[i_B][j_B] = Max2(i_B, j_B); } } } } } } ////////////////////////////////////////////////////////////// /////find the max value from matrix B when row < colume ///////////////////////////////////////////////////////////// int SquaMatrix::Max1(int i_B, int j_B){ for (int a =0; a<= i_B; a++){ for (int b=j_B; b< j; b++){ if (a <= i_B && b >= j_B ){ if( A[a][b] > temp ){ temp = A[a][b]; } } } } return temp; ; } ////////////////////////////////////////////////////////////// ///////find the max value from matrix A when row > colume ////////////////////////////////////////////////////////////// int SquaMatrix::Max2(int i_B, int j_B){ for (int a =i_B; a< i; a++){ for (int b=0; b<= j_B; b++){ if (a >= i_B && b <= j_B ){ if( A[a][b] > temp ){ temp = A[a][b]; } } } } return temp; } //////////////////////////////////////////////////////////// /////Print the results //////////////////////////////////////////////////////////// void SquaMatrix::Print(){ cout<<"Square Matrix A: "<<endl; for (int a = 0; a < i; a++){ for(int b=0; b<i; b++){ cout<<A[a][b]; } cout<<endl; } cout<<"Square Matrix B: "<<endl; for (int a2=0; a2<j; a2++){ for(int b2=0; b2<j; b2++){ cout<<B[a2][b2]; } cout<<endl; } } /////////////////////////////////////////////////////////// /////creat a main() to test the computer() ////////////////////////////////////////////////////////// int main(){ SquaMatrix S_M(5,5); //initialize the size of matries S_M.Generate(); //i need the given Square matrix A S_M.Compute(); //Compute Square matrix B bases on A S_M.Print(); //Print both Matries return 0; }
Is the 251 compiler really C++?
well, if you want faster, you have to reduce 'abstraction' The more your language abstract you from the processor, the slower it will run. The very best C compiler will be a tad slower that the very best assembler code, the very best C++ compiler will be slower than a decent C compiler. So, if you want faster, write the darn thing in assembler. Erik
... or just increase the clock frequency ;-)
