XC166 - Problem Notificiation - FLASH module
Dear attendees of the discussion forum,
we got the following information from INFINEON concerning the FLASH module:
SAx-C161CJ-16F20F/40F Step AC/AD
SAx-C164CS-16F20F/40F Step AC/AD
SAx-C164CS- 8F20F/40F Step AC/AD
SAx-C167CI -16F20F/40F Step AC/AD
Related to all temperatures and frequency for devices listed above.
Problem:
Code execution from internal flash module/
Operand read access from/to internal flash module
The problem depends primarily on the internal CPU frequency and the number of wait states selected for the flash module
( bit field WSFLASH in register IMBCTR ).
But ambient temperature and Vddi may have influence
( that is statistically more likely).
If the problem occurs it will typically result in a class B trap
( program access error, indicated by flag PACER = 1 in register TFR )
Avoid the problem with the following settings and limits:
a)ambient temperature: -40°C < Ta < + 85°C
fCPU < 16 MHz
                0 WS
		( bit field WSFLASH = 00b )
16 MHz < fCPU < 32 MHz
                1 WS
		( bit field WSFLASH = 01b )
                Default after RESET
fCPU > 32 MHz
                2 WS
	        ( bit field WSFLASH = 10b )
b) ambient temperature:  Ta >  85°C
fCPU < 16 MHz
               0 WS
16  MHz  <  fCPU < 28 MHz
               1 WS
               Default after RESET
   fCPU > 28 MHz
               2 WS
Performance:
The performance due to an additional waitstate depends on individual characteristics of the software.
Due to the internal instruction prefetch queue, the average performance decrease, when using 1 wait state instead of 0 is expected to be approximately 5%,
and approx. 15 % if you use
2 wait states instead of 1.
BTW: Up to now only one case in the field
has occured.
Stefan
  • Hi,
    may I know where exactly did you get this interesting info? It seems that one of our clients is having this problem (PACER trap on apparently exact instructions) and setting two waitstates on internal FLASH solves it, but of course he would like to have official info from IFX about it.
  • Hi,
