Failure in using of volatile
Hallo ALL,
I have the following problem ....
I use F005 from cygnal.
I have a timer:
idata U8 volatile HeartbeatLEDTimer;
idata U8 volatile DACTimer;
void Timer0InterruptHandler(void) interrupt 1 using 1
// Reload the timer registers
TR0 = 0;
TL0 = T0_RELOAD_LOW;
TH0 = T0_RELOAD_HIGH;
// DECREMENT_TIMER(HeartbeatLEDTimer);
DECREMENT_TIMER(DACTimer);
TR0 = 1;
and in the main()
if(!HeartbeatLEDTimer) {pin_LED_D1 = ~pin_LED_D1; HeartbeatLEDTimer = HEART_BEAT_LED_TIMER;}
// INTERRUPTS_OFF;
DACTimer=DAC_TIMER;
// INTERRUPTS_ON;
while(DACTimer != 0){; }//delay
it works without INTERRUPTS_OFF if I don't use HeartbeatLEDTimer, but if I use it, I should disable interrupts only before DACTimer=DAC_TIMER and not before HeartbeatLEDTimer = HEART_BEAT_LED_TIMER???
I'm really confused and I thought the problem is in VOLATILE! But it's not so clear.
Please help me to understand what here is really happened.
With best regards,
Sergey
