hi members... i'm programming assembler and likewise c. a practical training force me to write assembler in c. the serial port names P3.1 and i can send every time 8 bit (2bit = start- and stopbit and the last 6 bit's are data). i must abide the exactly speed (baudrate) for my pc and microcontroller. in assembler is that very easy because i can use the cycle's. i have realized the delay with loops in c but the loops are very inexactly! i've got the answer to use the processortime or related. How!?!?! thank's for you sympathy yours sincerely nick
Are you trying to communicate with a 'normal' RS232 serial port on a 'normal' PC?
Reading the original post, it seems that he is trying to implement RS232 baud timings using delay loops. Not easyily done in 'straight' C... The obvious suggestion would be to use a UART (then the conversion from assembler to C would be fairly simple), or if the UART is banned (in the assignment), then use a timer interrupt.
yes i'm working with rs232! thank for you sympathy!
"yes i'm working with rs232" I assume that means you are communicating with a 'normal' PC serial port? In that case, use the UART. You don't need to bit bang. If it is an assignment that forbids use of the UART then post your complete, compilable code and someone will probably offer some help.
Trying to write precise delay loops in 'C' is futile. If this is what the assignment requires, then it is a stupid assignment! Trying to write precise delay loops in 'C' is futile because the only way to know precisely how long the loop will take is to examine the generated assembler. And every time you re-compile, you must re-examine the generated assembler to ensure that it is still exactly the same. Since you're going to have to keep on examining the generated assembler anyhow, you might as well just write it once in assembler and be done with it! Do not try to write precise delay loops in 'C'!!!
thanks at first... that is the problem.... it's must have the same time (processor and microcontroller) in assembler anyway!?!?? it's never mind in serial with c? i'm must send data impulse every assigned time. that's only a supposition, i need help :) thanks..
"that is the problem...." What is the problem? Quote some context. "it's must have the same time (processor and microcontroller) in assembler anyway!?!??" Is this a question or a statement? Either way, explain what you mean. "it's never mind in serial with c?" I can't make any sense of this. "i'm must send data impulse every assigned time." Yes. "that's only a supposition" What is? "i need help" You need to explain what the problem is. These disjointed phrases full of "??!!??!!" and "..." are useless. We understand that your english is not very good but you could at least try and have the decency to write complete sentences. This is not a chat room.
i have solved the problem alone... i have write the folowing timer function (delay of one second): void timer(void) { #define TF0_VECTOR 1 int R7=20; TR0=0; TF0=0; TMOD=TMOD | 0xF0; //Timer 0,16 bit Timer TMOD=TMOD & 0x01; TL0=0xAF; //Timer 0, set 1 second TH0=0x3C; TR0=1; //start timer while(R7!=0) { if(TF0!=0) //test if the timer overflow { TR0=0; //stop timer TF0=0; //clear the overflow flag R7--; TR0=1; } } } Thank's for you help yours sincerely nick
