Why are those warnings comming? Build target 'Target 1' Compiling step.c... assembling step.src... linking... ***WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C?SLCMP MODULE: Step.obj(STEP) ***WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_STARTUP MODULE: Step.obj(STEP) ***WARNING L2: REFERANCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C_SLCMP MODULE: Step.obj(STEP) ADDRESS: 023EH "step" - 0 Error(s), 3 Warning(s). CASE I When I am putting the inline assembly code (I am doubtful about the technic.) HEXtoASCII(Count), the above warnings are coming. Also the main code is not starting from the origin (Means it is not even giving any jump to the starting address of Main code) It is directly starting one of the subroutine from 0000h location. CASE II When I am removing the HEXtoASCII(Count) subroutine, everything is going fine. What could be wrong? The hex code is... HEXtoASCII(Count) { /*#pragma asm MOV R6, #00H; MOV A, Count; MOV B, A; ANL A, #0FH; DA A; MOV R7, A; MOV A, B; ANL A, #0F0H; SWAP A; JZ TO; MOV B, A; CLR A; HERE: ADD A, #16H; DA A; JNC HI INC R6; HI: DJNZ B, HERE; TO: ADD A, R7; DA A; JNC NET INC R6; NET: MOV B, A; ANL A, #0FH; ADD A, #30H; MOV i, A; MOV A, B; SWAP A; ANL A, #0FH; ADD A, #30H; MOV j, A; MOV A, R6; ADD A, #30H; MOV k, A; MOV A, B; MOV B, R6; #pragma endasm*/ } And this is the C code from where I am calling the function HEXtoASCII. void Function(void) { idata char C[] = {"Count = "}, D[] = {"Final Count ="},i; //BACKLIGHT = 1; ClearDisplay(); for(a=0;a<8;a++) { WriteLCDData(C[a],a); } while(1) { if(INR == 0) { Count++; a = 8; for(i=0;i<255;i++); WriteLCDData(Count,a); } if(DCR == 0) { Count--; a = 8; for(i=0;i<255;i++); WriteLCDData(Count,a); } if(ENTER == 0) { if(Count<200) { Count = Count % 200; } for(a=0;a<13;a++) { WriteLCDData(D[a],a); } a = 13; WriteLCDData(Count,a); Rotate(); break; } } }
http://www.keil.com/support/docs/1646.htm Jon
Hey thanks for that Jon
