Hi , I want to use external interrupts of 89C51 to receive/transmit data using sync modem. Following is the C code i have written but that is not working.I'm using evaluation version of Keil Compiler . I have following doubts about ISR in C 1. Do we need to enable and disable the interrupt in its ISR to prohibit it to interrupt unless its ISR is over. 2. It it necessary to specify the register bank ( using 1 ..... etc ) 3. To set serial port baud rate do we need to set TCON regs , default C51 setting is sufficient or not. 4. Do I need to modify startup.a51 file for this code. Can anybody suggest me any other way to control sync modem ( source code or any url ) ? thaks Sanjay
/*;Program to Transmit data to GMSK CMX469 Modem ;Int0 -> Applied RxSync clock used for data sending P3.2 ;Int1 -> Applied Txsync clock used for data receiving P3.3 ;P1.0 -> Tx data ;P1.1 -> Rx data ;P1.2 -> Carrier Detect */ #include <reg51.h> #include <stdio.h> //void ReceiveData(void); //to be called by interrupt ISR //void TransmitData(void); //to be called by interrupt ISR void InitializeInterrupts(void); void InitSerialPort(void); static void INT0_ISR (void); //RX Sync clock static void INT1_ISR (void); //TX sync clock void main() { InitSerialPort(); InitializeInterrupts(); while(1) { P0=0xff; P2=0xff; } } static void INT1_ISR (void) interrupt 2 using 1 //for tx { EX1=0; //disable int1 P2=0x00; // making it zero to know whether intr has ocured on falling edge // TransmitData(); //function to tranmit data EX1=1; //enable int1 } static void INT0_ISR (void) interrupt 0 using 1 //for receive { EX0=0; //disable int0 P0=0x00; // making it zero to know whether intr has ocured on falling edge //ReceiveData(); //function to receive data EX0=1; //enable int0 } void InitializeInterrupts(void) { EX0=1; IT0=1; //falling edge EX1=1; IT1=1; //falling edge EA=1; } void InitSerialPort(void) { SCON = 0x52; /* SCON */ /* setup serial port control */ TMOD = 0x20; /* TMOD */ /* hardware (9600 BAUD @12MHZ) */ TCON = 0x69; /* TCON */ TH1 = 0xfd; /* TH1 */ //9600 baud rate TR1=1; printf("\nModem Program is running\n"); }
1. Do we need to enable and disable the interrupt in its ISR to prohibit it to interrupt unless its ISR is over. No you do not need to do this. An interrupt cannot itself be interrupted except by an interrupt of a higher priority. You do not seem to be implementing any high priority interrupts, so no problem. 2. It it necessary to specify the register bank ( using 1 ..... etc ) No, it is not absolutly necessary. In general it is best to specify a register bank because it makes context switching quicker. However, if an ISR is quite trivial, not specifying a register bank can actually result in quicker code. 3. To set serial port baud rate do we need to set TCON regs , default C51 setting is sufficient or not. 4. Do I need to modify startup.a51 file for this code. No, that should not be necessary. Interrupt vectors (is that what you have in mind) etc are all taken care of by the compiler.
Thanks alot Mr. Graham Cole for ur quick reply. In my C code as a result of External interrupts I expect sharp pulse at port P0 and P2 during falling edge of the clock pulse applied on the INT0 and INT1 pins. I observed the result ,instead of sharp pulse many transitions i'm getting. What may be the problem Pls reply. One more doubt: during executing ISR is there any chance of corrupting the previous data.Do we need to do push pop like thing in ISR or its taken care in Keil Compiler thanks again for ur reply Sanjay
Pls wd u considr rding sum manuls?
