Last June, someone asked about how command line symbols defined for both the assembler and the C compiler could be referenced within a conditional (if) statement within a universal shared header file. A company rep said they'd forward this to the tech team for advice. Whatever happened? The issue is this: Symbols of identical name specified on the command line for the assembler and the C compiler end up being unique symbols. Those specified for the assembler are defined as per a "$set" directive and are visible only to the assembler. Those specified for the C compiler are defined as per a "#define" directive and are only visible when running the compiler. In other words, there is no way to define a symbol on the A51 assembler command line that will be visible to the C preprocessor within the assembler. Symbols defined this way are only visible to "$if" statements. PROBLEM: A universal header file containing an "#ifdef SYMBOL" conditional branch will work within C modules, but will not work within assembler modules because the assembler's C preprocessor WILL NOT recognize the referenced symbol and will thus test false. Example:
#ifdef SYMBOL #include <me.h> #endif
#define SYMBOL
How about running the .h file through the preprocessor (only) with the command-line option of your choice, and then feeding it to the assembler? It's not obvious to me that the COND/NOCOND directives are exactly what you want. But there's always a standalone preprocessor like GNU cpp.
Using the gnu preprocessor to generate an intermediate file is a great suggestion and I believe that would work, albeit not as "simple elegant" as we might like. Thank you! I was just thinking of another approach. I am going to attempt this, but might it be possible to define an assembler level macro that could be used within the header file to generate alternate "code" (i.e. text) based on whether or not the assembler is running? I believe there are predefined symbols that can be tested to determine if the C compiler or the assembler is running... To be continued...
P.S. For interested parties, the way we are handling this issue today is to maintain essentially identical ".inc" and ".h" files for the desired headers, thus, totally defeating the desire to maintain a SINGLE header file. The "GIZMO.inc" files are included in assembler modules and the "GIZMO.h" files are included in C modules. The ".inc" contains '$if' logic (and '$include', etc.) and the ".h" contains '#ifdef' logic and (and '#include', etc.) This is obviously suboptimal and mistakes happen.
The problem is not that the assembler won't recognize #define-type symbols --- it will do that just find. The problem used to be that you can set such macros in an assembler run from outside the source file. I.e. you could
#define TURN_ON_OPTION_FOO 1
Kudos to Mr. Broeker! The DEFINE command line option is EXACTLY what we were looking for. And to think it has been there for all this time! It would appear that the online updates distributed by Keil in recent years/months do not always contain equally updated documentation. The DEFINE command line option is not mentioned in the PDF version of the Assembler User Guide that we have and, unfortunately, this feature had totally eluded us until this moment. Note to self: Regularly scan all Release Notes published by Keil on their website! Thank you again Mr. Broeker. Problem solved!
It would be nice if the assembler would accept any .h file. Often I have to make several to separate out what the assembler can not handle. Obviously it would not make much sense for the assembler to recognize a struct (converting all entries to offset, however could be usefun) but could it maybe just skip it instead of complaining? also extern array should not be a problem. Erik
I have to agree with others here that problems resulting from "bilingual" API/include files (fully compatible with the compiler or assembler) can be a real headache, and I'm sure we've all come up with our work-arounds. Keil likely has to prioritize its feature/fix tasks, but considering that the targets are relatively small controllers, assembly language requirements aren't uncommon. Given this, providing a robust common syntax between assembler and C would be a big benefit IMO. If it were me, I'd look at the header files in C format and ask, "how can we make the assembler understand as much of this as possible, if no all of it?" (my 2c)
If it were me, I'd look at the header files in C format and ask, "how can we make the assembler understand as much of this as possible, if no all of it?" - and ignore the rest (my 3c) Erik
Yes, that too. Frankly, I don't know why it couldn't index structures (somehow) as you suggested, resolve prototypes, and much more.
Frankly, I don't know why it couldn't index structures (somehow) as you suggested, resolve prototypes, and much more. Well, as it reached the "much more" part of that request, at the latest, it would be a mostly complete re-implementation of the existing C compiler. I hope you can agree that creating such a beast would be a waste of everyone's time and money. If you want to use all kinds of C constructs, A51 is not the place to go looking for them.
Often I have to make several to separate out what the assembler can not handle. Hmm... what's wrong with just putting a big
#ifdef __C51__ /* ... */ #endif
The funny thing about your suggestion is that one of the things the assembler can not handle is #ifdef. Erik
Actually it does. I already use that one.
Well, as it reached the "much more" part of that request, at the latest, it would be a mostly complete re-implementation of the existing C compiler. I hope you can agree that creating such a beast would be a waste of everyone's time and money. Actually, it would be a re-implementation of the A51 assembler...a likely far simpler interpreter than the compiler, in that its simply translator. As far as it being a waste of time or money, I dont know? Intel thought it important to include constructs such as structures into ASM-86. If you want to use all kinds of C constructs, A51 is not the place to go looking for them. Its my users that want C constructs in a libraries API. Said library I must code in assembly. The less cluttered the API file (i.e. more compatible with the A51 implementation), the more readable the user will find it to be.
that must be in a revison later than when I gave up on it. Not necessarily later than the one I use (7.xx). Erik
