I use #define Ring FARRAY (log_message_t, RING_LOCATION) with version 7.07 I can cross 64K banks as long as the structure log_message_t has a size which is a power of 2. For example if log_message_t is 8 bytes I can address Ring[(unsigned long)Idx].reader and the index Idx can be 10000 addressing 80000 bytes. with version 7.50 of the compiler this DOES NOT WORK what should I use. Thank you
In what way does it not work?
We need a clear error description (preferable a test case that runs under the simulator) to help you in this case. Reinhard
