Object file not found
I have just installed Keil UVision2 and are trying out the included example rtx_ex1. I want to run it on the simulator for an Infineon C167CR-LM processor. When I build the project, i get
FATAL ERROR L210: I/O ERROR ON INPUT FILE:
EXCEPTION 0021H: PATH OR FILE NOT FOUND
FILE: Rtx_ex1.obj
I have not done any changes to the project, other than changing to the correct processor "device for target..."
Should'nt uvision2 create this file when it is not there?
What to do?
Regards,
Ray
