While Developing the code in compiler for P89CLPC932, getting the following error message. The message is: Build target 'Target 1' compiling serial.c... SERIAL.C(1): warning C500: MISSING DEVICE (SECURITY KEY NOT FOUND) compiling reg935.h... REG935.H(1): warning C500: MISSING DEVICE (SECURITY KEY NOT FOUND) linking... BL51 BANKED LINKER/LOCATER V5.01 - SN: COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 "serial.obj", "reg935.obj" TO "UART" RAMSIZE(256) *** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: serial.obj Target not created How can I come out from this problem. This is the first time who I am working with the KEIL software.
You get this message because this version is not an Evaluation Version. Jon
"You get this message because this version is not an Evaluation Version." ie, you have a Full version, but don't have the hardware security key (or "dongle") needed to enforce the licence. See these threads about Dongles: http://www.keil.com/forum/docs/thread2369.asp http://www.keil.com/forum/docs/thread5430.asp There is a Dongle Testing Application available under: http://www.keil.com/download/docs/chkdongle.exe.asp. You can donload the evaluation software here: http://www.keil.com/demo/ Be sure to read the limitations here: http://www.keil.com/demo/limits.htm Also, be sure to follow the installation instructions carefully - to make sure that it does install as an evaluation (otherwise it will need a dongle!)
Thank you very much Andy. I will try with the links u provided. hari
