When i compile my code in the uvision3 and try to Debug i get the message: Memory Mismatch! Address: 0x00000018 Value = 0x18 Expected = 0xF0 This address corresponds to the code LDR PC, [PC, #-0x0FF0] /* Vector from VicVectAddr */ I'm using ULINK V2.00 and MCB2100 V2
http://www.keil.com/support/docs/2764.htm Jon
I didn't understand. What are the "default settings"? The error I've described occurs when I disconnect J1 and J7. But when I put them, I receive a error message "JTAG communication failure"....
Are you using the UART0 for standard communication? In this case you need to switch J1 - ISP to OFF.
