hey .. which library needs to be included when we are using the swatch(float secs) function ?? thanks pruthvi
hi .. then how do we use in our c programs for generating some delay .. can u sight some examples of this swatch() ?? regards pruthvi
Hmm... delay... There are many different delays: 1. do nothing: { unsigned count = NUMBER_OF_TIKS; while(--count ){;} } 2. only wait for event, for example using timer0 ( timer and interrupts must be configured) unsigned char count ; static void timer0_isr (void) interrupt 1 { ..... if(count)count--; } void func(){ .... count = NUMBER_OF_TIKS; while (count){;} ... } 3. wait and do something else unsigned char count ; bit then_continue; static void timer0_isr (void) interrupt 1 { ..... if(count)count--; } void one(void){ count= NUMBER_OF_TIKS; then_continue=1; } void two(void){ if (!then_continue ) return; if (count) return; .... // delay finished! } void main(void) { count =0; then_continue =0; while (1) { .... if( .... ) one(); // start delay two(); .....// } }
