MULTIPLE CALL TO SEGMENT
Hi All,
I've a warning message : MULTIPLE CALL TO SEGMENT L15
The problem comes from 2 different ISRs that call the same function.
What I dont understand is that both callers are ISRs and therfore the called function will not be called at the same time.
I use keil 7.07 for an2131 cypress (ezusb),
here is my code :
#pragma NOAREGS
static void Check_Data_Received(unsigned char data_received)
MIDI_In_Add_Buffer(data_received, &MIDI_In_From_Con);
static void MIDI_In_Add_Buffer(unsigned char data_in, Midi_In_Struct *midi_struct)
#pragma AREGS
static void serial_port_0_isr (void) interrupt COM0_VECT using 1
BYTE data_received;
Check_Data_Received(data_received);
void ISR_Ep2out(void) interrupt 0
MIDI_In_Add_Buffer(OUT2BUF[index+frame+1], &MIDI_In_From_Usb);
The warning is as follow :
*** WARNING L15: MULTIPLE CALL TO SEGMENT
SEGMENT: ?PR?_MIDI_IN_ADD_BUFFER?ITR
CALLER1: ?PR?SERIAL_PORT_0_ISR?ITR
CALLER2: ?PR?USB_JUMP_TABLE?USBJT
Any help greatly appreciated
