problem with monitor configuration for uart2
hello ..
my micro for an specific application has two uarts on chip.
how do you configure the monitor-51 for the second uart2,which has different address mapping in sfr registers and also my micro works at 3.58 MHz freq .
the address mapping of uart2 is as follows...
scon - 0xc0
sbuf - 0xc1
sbaudL - 0xc2
sbaudH - 0xc3.
suppose, i need to configure uart2 say for 9600 bps.
what all things need to be changed in install.a51 file ..??
which command should be used to generate mon51.hex file ..??
example :
install 1..2(serial type) 7f 0
I am not gettting which serial type to use,
with the install command ??
thanks ..
pruthvi
