This is a cut down version of my program. This should gives the basic idea of what I'm doing which is counting pulses using (T0) and (T1) and comparing them to each other. The problem I'm having is that TL1 is not counting it acts like it timing.
#include <reg51.h> void main (void) { int Board_a; int Board_b; TMOD = (TMOD & 0xF0) | 0x05; TR0 = 1; TR1 = 1; while (1) { TL0 = 0; TL1 = 0; while (TL0 <= 100){} Board_a = TL0; Board_b = TL1; if (Board_a < Board_b) {//increase the voltage output to the firing board } if (Board_a > Board_b) {//decrease the voltage output to the firing board } }
Hi Glenn, the line 'TMOD = (TMOD & 0xF0) | 0x05;' only sets T0/MO0 as a counter, you need to replace this line with:- TMOD = 0x55; so that both T0 and T1 are now initialised with the same settings. Mark.
Thank you Mark for the info. My program is now controlling like a champ.
