Hi all I ve created a bank for constant using
?B_CB EQU 3 in the file L51IBANK.A51
IMPROPER FIXUP errors indicate that the linker needs to access something that is inaccessible (mainly because there is no addressing mode supported in the instruction set). For example, an AJMP to an address that is too far away (more than 11 bits of address space). It may be that in moving your constants around, you have located a jump table for a switch statement too far away from the switch code for it to work. Or, worse, you have located the jump table in a different code bank. Jon
I've just started to use LX51 extended linker, when I try to creat an application consisting 4 banks with bankarea 0x0200-0x0400 altough "COMMON AREA" bigger than 0x0200H byte My project built succesfully.
when I try to creat an application consisting 4 banks with bankarea 0x0200-0x0400 altough "COMMON AREA" bigger than 0x0200H byte My project built succesfully If you check the linker MAP file, you'll find that the linker duplicated the excess common area in each of the code banks. Jon Note: It's not a good idea to put your text in a pre block since those kinds of blocks preserve formatting, don't wrap text, and don't insert line breaks. That's why your post is so wide.
* * * * * * * * * * * C O D E M E M O R Y * * * * * * * * * * * * * *** CODE BANK 0 *** 000700H 00070BH 00000CH BYTE UNIT CODE/B0 ?PR?FUNC0?C_BANK0 00070CH 00070CH 000001H BYTE UNIT CODE/B0 ?PR?INTRP0?C_BANK0 *** CODE BANK 1 *** 000700H 00070BH 00000CH BYTE UNIT CODE/B1 ?PR?FUNC1?C_BANK1 00070CH 00070CH 000001H BYTE UNIT CODE/B1 ?PR?INTRP1?C_BANK1 *** CODE BANK 2 *** 000700H 000708H 000009H BYTE UNIT CODE/B2 ?PR?FUNC2?C_BANK2 *** CODE BANK 3 *** 000700H 000762H 000063H BYTE UNIT CODE/B3 ?CO?C_ROOT 000763H 0007A1H 00003FH BYTE UNIT CODE/B3 ?CO?C_BANK1 0007A2H 0007DFH 00003EH BYTE UNIT CODE/B3 ?CO?C_BANK0 0007E0H 00080EH 00002FH BYTE UNIT CODE/B3 ?CO?C_BANK2 *** COMMON AREA *** 000000H 000002H 000003H --- OFFS.. CODE ?CO?L51IBANK?3 000003H 000005H 000003H BYTE OFFS.. CODE ?C_BANK0?00003 000006H 00000AH 000005H --- --- **GAP** 00000BH 00000DH 000003H BYTE OFFS.. CODE ?C_BANK1?0000B 00000EH 000372H 000365H BYTE UNIT CODE ?PR?PRINTF?PRINTF 000373H 000412H 0000A0H BYTE UNIT CODE ?C_C51STARTUP 000413H 0004B0H 00009EH BYTE UNIT CODE ?C?LIB_CODE 0004B1H 0004D7H 000027H BYTE UNIT CODE ?PR?PUTCHAR?PUTCHAR 0004D8H 0004F0H 000019H BYTE UNIT CODE ?C_INITSEG 0004F1H 000508H 000018H BYTE UNIT CODE ?BANK?SELECT 000509H 00052AH 000022H BYTE UNIT CODE ?PR?MAIN?C_ROOT
* * * * * * * * * * * C O D E M E M O R Y * * * * * * * * * * * * * *** CODE BANK 0 *** 000500H 00050BH 00000CH BYTE UNIT CODE/B0 ?PR?FUNC0?C_BANK0 00050CH 00050CH 000001H BYTE UNIT CODE/B0 ?PR?INTRP0?C_BANK0 *** CODE BANK 1 *** 000500H 00050BH 00000CH BYTE UNIT CODE/B1 ?PR?FUNC1?C_BANK1 00050CH 00050CH 000001H BYTE UNIT CODE/B1 ?PR?INTRP1?C_BANK1 *** CODE BANK 2 *** 000500H 000508H 000009H BYTE UNIT CODE/B2 ?PR?FUNC2?C_BANK2 *** CODE BANK 3 *** 000500H 000562H 000063H BYTE UNIT CODE/B3 ?CO?C_ROOT 000563H 0005A1H 00003FH BYTE UNIT CODE/B3 ?CO?C_BANK1 0005A2H 0005DFH 00003EH BYTE UNIT CODE/B3 ?CO?C_BANK0 0005E0H 00060EH 00002FH BYTE UNIT CODE/B3 ?CO?C_BANK2 *** COMMON AREA *** 000000H 000002H 000003H --- OFFS.. CODE ?CO?L51IBANK?3 000003H 000005H 000003H BYTE OFFS.. CODE ?C_BANK0?00003 000006H 00000AH 000005H --- --- **GAP** 00000BH 00000DH 000003H BYTE OFFS.. CODE ?C_BANK1?0000B 00000EH 000372H 000365H BYTE UNIT CODE ?PR?PRINTF?PRINTF 000373H 000412H 0000A0H BYTE UNIT CODE ?C_C51STARTUP 000413H 0004B0H 00009EH BYTE UNIT CODE ?C?LIB_CODE 0004B1H 0004D7H 000027H BYTE UNIT CODE ?PR?PUTCHAR?PUTCHAR 0004D8H 0004F0H 000019H BYTE UNIT CODE ?C_INITSEG 0004F1H 00060EH 00011EH --- --- **GAP** 00060FH 000626H 000018H BYTE UNIT CODE ?BANK?SELECT 000627H 000648H 000022H BYTE UNIT CODE ?PR?MAIN?C_ROOT
Actually Compiler dont duplicate (as seen from .MAP file) excess code part to other bank. Actually, it does. It just still calls it COMMON and only lists it in the COMMON AREA. These segments...
