loading PLL control register - Default value
Hi
i'm using UV3 for Infineon XC164CS-DAvE project.i'm facing a problem while debugging the DAvE generated files. During the dubugging, PLL Control register is added with default value..but while the instruction executes for loading this register PLLCON with 0x7814,it hangs and giving the msg :" Connection to the TARGET SYSTEM LOST". here is my config settings.
Configuration of the System Clock:
-VCO clock used, input clock is connected
-input frequency is 8 MHz
-VCO output frequency 100 .. 150 MHz
-system clock is 20 MHz
fin = 4Mhz
fpll =20MHz
fvco =100MHz
fcpu =20MHz
Plz,let me know if anyone has a solution.
  • What are you using for Debugging. If it is the Monitor, this instruction will change the Baudrate and breaks therefore monitor communication.
    Actually, it is recommended to use the OCDS Debugging facilities (for example with Keil ULINK) for testing this device. ULINK does not have this problem and allows also software testing in FLASH ROM.
