Trying to acquire input from keyboard on ASC1
Hello. I want to get key from keyboard not using the default Serial #1 but using Serial #2 that i suppose is connected with ASC1.
So i configure the port 3, the direction pin, and alternate operation.
this is the piece of code.
#include <stdio.h>                /* standard I/O .h-file              */
#include <XC161.h>                /* special function register XC161   */
#include <math.h>
signed char _getkey (void)  {
  char c;
  while (!ASC0_RIC);
  c = (char) ASC1_RBUF;
  ASC1_RIC = 0;
  return (c);
/* main program */
void main (void)  {               /* execution starts here               */
    char nome[10];
    int i;
    int j=0;
/* initialize the serial interface     */
#ifndef Monitor         /* do not initialize if you use Monitor-166      */
  P3  |= 0x0400;        /* SET PORT 3.10 OUTPUT LATCH (TXD)              */
  P3  |= 0x0002;
  DP3 |= 0x0400;        /* SET PORT 3.10 DIRECTION CONTROL (TXD OUTPUT)  */
  DP3 |= 0x0002;
  DP3 &= 0xF7FF;        /* RESET PORT 3.11 DIRECTION CONTROL (RXD INPUT) */
  ASC0_TIC = 0x80;      /* SET TRANSMIT INTERRUPT FLAG                   */
  ASC0_RIC = 0x00;      /* DELETE RECEIVE INTERRUPT FLAG                 */
  ASC0_BG  = 0x40;      /* SET BAUDRATE TO 9600 BAUD @ 20MHz             */
  ASC0_CON = 0x8011;    /* SET SERIAL MODE                               */
  ALTSEL0P3 |= 0x0C00;  /* Configure port pins for serial interface 0    */
  ASC1_TIC = 0x80;      /* SET TRANSMIT INTERRUPT FLAG                   */
  ASC1_RIC = 0x00;      /* DELETE RECEIVE INTERRUPT FLAG                 */
  ASC1_BG  = 0x40;      /* SET BAUDRATE TO 9600 BAUD @ 20MHz             */
  ASC1_CON = 0x8011;    /* SET SERIAL MODE                               */
  ALTSEL0P3 |= 0x0002;  /* Configure port pins for serial interface 0    */
#endif
  while (1)
  	printf("valore registro RSTCON: %0xh \n",RSTCON);
	printf("Causa del reset: %0xh \n",SYSSTAT);
	printf("Sorgente di configurazione: %0xh \n",RSTCFG);
   // printf("valore di SYSCON1 :%0xh \n",SYSCON1);
//	printf("valore di SYSCON2 :%0xh \n",SYSCON2);
	printf("valore di SYSCON3 :%0xh \n",SYSCON3);
	i=-1;
    nome[0]='a';
              /* An embedded program does not stop and    */
	do
 		i++;
		nome[i]=_getkey();
        printf("%c",nome[i]);
	while (nome[i]!=0x00A);
    printf("Ciao, ");
   	printf(nome);
  }                          /* loop.  You may wish to put in your own   */
}                            /* code were we've printed the dots (...).  */
But this doesn't work
Does somebody explain me why?
Thanks!!
