uv2 - ds80c400 - code/ecode/const/hconst cosntant arrays
I am having a bit of a problem with constant arrays on the ds80c400 i.e. char y[] = {1,2,3,4};
Note: the ds80c400 has a 16M contiguous memory map.
example 1:
in the following code the array is placed in segment CONST.
#include <stdio.h>
char foo (int x)
  char y[] = { 1,2,3,4};
  return(y[x]);
example 2:
in the following code the array is placed in segment CODE.
#include <stdio.h>
char foo (int x)
  printf("1234%d",1);
  return(y[x]);
Question 1:
why do these get placed into CONST/CODE segments and not HCONST/ECODE?
Question 2:
why sometimes CONST and some time CODE?
Question 3:
by default uv2 does not define the CONST segment for the ds80c400.
I know that I can force the data into HCONST with the type "far const" or I can define the CONST segment, but both these have drawbacks in my design. Is there a compiler switch or method to have these default to the HCONST/ECODE segments (or alternativly but less preferable the CODE segment)?
