Hi I have the problem, that I want to execute a 'ClockTick' each 100ms, and a 'Do_Process' when a Signal is received. If I use: char OSEvent; OSEvent = os_wait(K_SIG+K_IVL,100,0); switch (OSEvent) { case TMO_EVENT : { ClockTick(); break; } case SIG_EVENT : { Do_Process(); break; } default : { LogWrite("Unknown\n"); } } I have the problem, that 'ClockTick' is executed in shorter intervals than 100ms when a lot of Signals are received. Seems that the interval timer is reseted whenever a signal occurs. In this way 'ClockTick' can be executed more than 10 times in a second, but it must not! Well, I can also use a timer: OSEvent = os_wait(K_SIG+K_TMO,100,0); But in this way it is no guaranteed, that 'ClockTick' is executed every 100ms. If I receive a lot of Signals, then 'ClockTick' is never executed. How can I solve this problem. According to the manual this should work with an interval. Please help me Tom
Yeah, it should but it doesn't :( RTX51 is written by another company and it seems that they do not support it any more. If you look at the dates of source files you will see that the latest changes were in 1996...and I cannot believe that in 8 years no new bugs were found...I have reported some problems too, but got no actual help. So, you can dig into kernel source (which you should have if you bought RTX51) and try to locate the bug and fix it... Dejan
