I am using a atmel 89s8252 controller which has 8k flash, 2k eeprom, and 256 ram.. I am using the evaluation version of the keil.. My question is would my program be compiled if i were to use the register version -> means i have to buy it. thanks ... Here's the error.
****************************************************************************** * RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 08F1H BYTE (111%) * ****************************************************************************** Program Size: data=55.2 xdata=0 code=2666 LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S) *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: C:\KEIL\C51\LIB\C51S.LIB (-----) LIMIT: 0800H BYTES
Crist, Yes... the program would have compiled with the registered version, and yes, this means you have to buy it.
http://www.keil.com/demo/limits.htm
