What does this message means..
I am using a atmel 89s8252 controller which has 8k flash, 2k eeprom, and 256 ram..
I am using the evaluation version of the keil..
My question is would my program be compiled if i were to use the register version -> means i have to buy it.
thanks ...
Here's the error.
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 08F1H BYTE (111%) *
Program Size: data=55.2 xdata=0 code=2666
LINK/LOCATE RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
    MODULE:  C:\KEIL\C51\LIB\C51S.LIB (-----)
    LIMIT:   0800H BYTES
