a Assembly file dis_buffer: DS (%END_ACQ_CHAP+1)*1024+(3*1024) ;[1][1024]
a C file extern unsigned char xdata dis_buffer[8][1024]; . . . dis_buffer[15][(5 * 15) + k] = (dis_buffer[15][k] & mask[(k % 15) % 3]);
It's quite impossible to judge what might or might not be wrong here, given the incomplete example: *) That '%' in your ASM file is a typo, I guess? *) what is END_ACQ_CHAP defined to be? There is an obvious error in the C part (you're addressing beyond the span of the first index), but due to the way C works, that may be impossible to catch by the compiler, depending on what the part of your C code you snippet away actually is.
"dis_buffer: ... ;[1][1024]" First dimension: 1 "extern unsigned ... dis_buffer[8][1024];" First dimension: 8 "dis_buffer[15][(5 * 15) + k] =..." First dimension: indexed with '15'. What's going on?
""Debugging is twice as hard as writing the code in the first place. Therefore, if you write the code as cleverly as possible, you are, by definition, not smart enough to debug it." --Brian Kernighan That's why I say, "You need to break this down into steps so that you can actually see & check what's going on!" You may also need to turn the optimisation down - otherwise the compiler might just optimise it back to where you started!
