ReadWrite EEPROM in 89S8252
I got a code, and modified it to run..
But i can't seem to get the code correct.
it has to do with XDATA but i can't seem to get it right.
#include <AT898252.H>
#include "lcd.c"
BYTE ReadEEPROM(int addr)
	char EEdata;
	WMCON |= 0x08; // Enable EEPROM memory space
	EEdata = addr; // --> how do u write here?
	WMCON &= 0xF7; // Disable EEPROM memory space
	return(EEdata);
// To write a single byte to a location in EEPROM.
void WriteEEPROM(int addr, char EEdata)
	WMCON |= 0x10; // Enable EEPROM memory write
	addr = EEdata; --> how do u write here?
	msdelay(15);
	WMCON &= 0xEF; // Disable EEPROM memory write
here's the assembly version..it worked..
but didn't manage to convert it into C.
WMCON DATA 96h ; watchdog and memory control register
EEMEN EQU 00001000b ; EEPROM access enable bit
EEMWE EQU 00010000b ; EEPROM write enable bit
WDTRST EQU 00000010b ; EEPROM RDY/BSY bit
ADDRESS EQU 10H
DATAS EQU 0AAH
; EEPROM read example.
;orl WMCON, #EEMEN ; enable EEPROM accesses
;mov dptr, #ADDRESS ; address to read
;movx a, @dptr ; read EEPROM
;xrl WMCON, #EEMEN ; disable EEPROM accesses
; EEPROM write example, utilizing fixed delay for write cycle.
; Delay is worst case (10 ms). Code for delay is not shown.
; Write is followed by verify (read and compare), but code to handle
; verification failure is not shown.
orl WMCON, #EEMWE ; enable EEPROM writes
mov dptr, #ADDRESS ; address to write
mov a, #DATAS ; data to write
movx @dptr, a ; write EEPROM
xrl WMCON, #EEMWE ; disable EEPROM writes
