I have this case of two virtually identical routines that must run at the ultimate speed. One approach would be:
RSEG ?DT?FormatBitSegment FBSfcol: DS 1 RSEG ?PR?FormatBitSegment?AVFMTBS USING 0 FormatScrollSegment: ...... mov a,FBSfcol ...... sjmp common FormatBitSegment: ...... mov a,FBSfcol ....... common: ....... ...... mov a,FBSfcol ...... ret
Surely this is how the "Common Tail Merge" optimisation works? So it must work!?
Thanks, Andy Would it not be absolutotally wunnerful if the manual index had cross references to "the same with other words" Erik
sort of a cross between an index & a thesaurus? That'd be really useful!
