I have an XC167 application that needs to place the code from two modules into the SROM class in order to copy code from Flash to the internal program memory. I can use the following in the User Sections of the Linker but this will not adapt automatically to the growth of the first module.
?PR?ABC%ABC_CODE(0xe00000)[], ?PR?DEF%DEF_CODE(0xe00400)[]
Hi Barry, unfortunetaly no, as far as I know. You have to get the length from a look inside the map file. But may be, you can combine your code in one class (using #pragma rename CODECLASS=YOURCLASS) for this module and locate the whole class, for e.g. MYCLASS(0xE00000-0xE00420) instead of: ?PR?ABC%ABC_CODE(0xe00000), ?PR?DEF%DEF_CODE(0xe00400) But you have also to get the length, from the map. I hope KEIL support can answer this question. Stefan
Try just to state the second section without address specification. So this should work: ?PR?ABC%ABC_CODE(0xe00000)[], ?PR?DEF%DEF_CODE[]
Dear KEIL team, thank's for support! ;-) Stefan
This is excellent! This whole SROM feature is great.
Well I tried this and it does not work unfortunately. Removing the exec_address causes the line in my code that copies this from Flash to RAM
hmemcpy(SROM_PS_TRG(ABC), SROM_PS_SRC(ABC), SROM_PS_LEN(ABC)); hmemcpy(SROM_PS_TRG(DEF), SROM_PS_SRC(DEF), SROM_PS_LEN(DEF));
*** ERROR L127: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _PR_DEF_s_ MODULE: ..\objFiles\MAIN.obj (MAIN) *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _PR_DEF_s_ MODULE: ..\objFiles\MAIN.obj (MAIN) ADDRESS: 002EH *** ERROR L128: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _PR_DEF_s_ MODULE: ..\objFiles\MAIN.obj (MAIN) ADDRESS: 0032H
I tried it out too, with an own little example and it works with the syntax as provided by KEIL's support. I was able to locate two datasections directly after each other and a codesection to a specific place. The syntax error was not reproduceable to me. I used following syntax with an own little testprogram I wrote:
?ID?MYSEC2%IDATA(0x00F600)[],?ID?MYSEC1%IDATA[], ?PR?TESTCLASS%NCODE(0xC0E000)
Hi Barry, may be under L166/MISC the box "Create Relocatable Output File (LINKONLY)" is checked ? If I do so I can produce unresolved externals. If you uncheck this, these errors should be disappear. I can reproduce this behaviour. A checked LINKONLY seems to be default. Stefan
Thanks Stefan but LINK_ONLY is not checked. Your example uses a data section. Have you tried using a code section, placing it in the SROM class and then copy the code to the RAM area as in Keil App Note 138? My code works correctly if the exec_address is included in the specification for each section I want placed in the SROM class but fails with the formerly mentioned errors when I remove the exec_address from all but the first User Section.
Hi Barry, no I did it not with the SROM class. I only checked the syntax. Generally I have used with code section, which was working too. Give me time to try and check out with SROM class. Stefan
That's me again. I try it and it will not work with SROM class. I played additionally with '&' sign to try append the second section directly, but there was not the effect, that areas for execution was append direct each after another. :-( Stefan
