I have an XC167 application that needs to place the code from two modules into the SROM class in order to copy code from Flash to the internal program memory. I can use the following in the User Sections of the Linker but this will not adapt automatically to the growth of the first module.
?PR?ABC%ABC_CODE(0xe00000)[], ?PR?DEF%DEF_CODE(0xe00400)[]
Hi Barry, unfortunetaly no, as far as I know. You have to get the length from a look inside the map file. But may be, you can combine your code in one class (using #pragma rename CODECLASS=YOURCLASS) for this module and locate the whole class, for e.g. MYCLASS(0xE00000-0xE00420) instead of: ?PR?ABC%ABC_CODE(0xe00000), ?PR?DEF%DEF_CODE(0xe00400) But you have also to get the length, from the map. I hope KEIL support can answer this question. Stefan
Try just to state the second section without address specification. So this should work: ?PR?ABC%ABC_CODE(0xe00000)[], ?PR?DEF%DEF_CODE[]
Dear KEIL team, thank's for support! ;-) Stefan
