Cross-posting from the 8052.com forum http://www.8052.com/forum/index.phtml A while back (http://www.8052.com/forum/read.phtml?id=23083), I asked about how to get a PC to read the 9th bit in Mode 2/3: Multiprocessor Serial bus format. I need to be able to detect the state of the 9th bit for each received byte. Mahmood Elnasser suggested the cport library: http://www2.arnes.si/~sopecrni/downloads/CPort263.zip I've downloaded this, and it doesn't look like it'll do the job :-( (It looks like it'll have the same problem as AsyncPro) The OnRxChar Event could return any number of characters, but the LastErrors Method - as its name suggests - only tells me what the last error was; ie, I can't tell which of the received bytes had the 9th bit set (Parity error). Any help would be greatly appreciated. I'm currently looking around at direct IO drivers for Windows (yes, I know it'd be a doddle in MS-DOS).
Are you saying you can't look at the 9th bit in your receive ISR?
on the 8051 (Triscend E5, actually) it's trivial. I want to make a Win32 PC-based monitor/tester, so I need to be able to see (or, at least, deduce) the 9th bit on a Windows PC
