The followings are from gs51.pdf: signal void one_thou_hz (void) { while (1) { /* repeat forever */ PORT2 |= 1; /* set P1.2 */ twatch((CLOCK/2)/2000); /*delay for .0005 secs*/ PORT2 &= ~1; /* clear P1.2 */ twatch((CLOCK/2)/2000); /*delayfor .0005 secs */ } /* repeat */ } But I consider the delay is 0.00025 instead 0.0005,because (CLOCK/2)/2000*1/CLOCK= 1/4000 ? Is it right?
Yes, this seems to be a manual error. We will correct this in the next version.
