Hi, Does anyone here ever use #message in other compilers? It is a useful tool for making sure that code with many #ifdef compiles the way you want without adding to the number of warnings. thanks, Martin
"Does anyone here ever use #message in other compilers?" I kind of doubt it, since it is not part of Standard C.
Thanks for the response. I realize it is not in the kernigan richie book, but I have seen it in other compilers and other books. It can be useful, though I understand that if someone did not know it existed, they would not use it. For and example of its use, if you want to test the version of something and do different things based on what you find in a header, then you print a message as some you may want to reserve warnings for things people really should take care of. What are your thoughts?
its simple #ifdef I_WANT_AN_ERROR_MESSAGE I screwed up #endif Will work just fine Erik
"What are your thoughts?" My thoughts are to not use facilities or extensions that are not part of the standard language unless there is absolutely no other way to accomplish a task. Since Standard C lacks a facility for echoing anything other than error messages (using #error), I echo build variation messages to a user using the command shell. I specify what I want to build to the make tool, which then passes the appropriate macro values to the compiler (subsequently choosing appropriate values and conditional compile paths in the C source and header files) and uses the shell for echoing messages telling the user what it's doing.
I may be naive, but that sounds like you are not using MicroVision2. If you want to use the ide, then I think what you suggest may be complicated (could be wrong on this though)
"If you want to use the ide, then I think what you suggest may be complicated" Although I haven't actually tried it, I think it should be quite easy using the Custom Translation facility...?
"...that sounds like you are not using MicroVision2." Ah yes, you are correct. Given the number of different processors and toolchains I deal with, I don't use anybody's IDE except for simulation/debug. Just like I design firmware to be as processor-independent as I possibly can, I use a build environment that is as toolchain-independent as I can possibly get it. I can't afford to be hamstrung dealing with vendors' IDE idiosyncrasies for editing, building, etc. "If you want to use the ide..." Now why would I want to do that? ;-) "...then I think what you suggest may be complicated (could be wrong on this though)" I think you'd be right (but I could be wrong).
I see your logic. I was given, a month to develop lots of code, and some sample code written in this environment that did some of the things I wanted. That made it easy for me to decide; use the sample code and the ide. Now I am fine tuning.
I said, "I don't use anybody's IDE..." I don't mean to imply that Keil's IDE is bad, so don't get me wrong. Keil's IDE is nice as far as IDEs are concerned. Now if all vendors plugged into a common flexible IDE like Eclipse, I might start using an IDE.
To my knowledge, #warning is not part of Standard C either. Your knowledge is apparently correct. At least from skimming the n869 draft for ISO C99, I don't see #warning mentioned. I was under the delusion it had been added for C99. But apparently not, and #warning is still just a non-standard extension (common or not).
