data stream detection
Hi All,,
My 8 bitcontroller is receiving a stream of pulses on one of its normal pins (ie., not an interrupt pin). The width of the pulses is either 300-microseconds or 1-milliseconds. So infact a binary 0 and 1 is being received in the form of pulse width.
If the pulse width is 300-microseconds then it is a logic zero.
If the pulse width is 1-milliseconds then it is logic one.
The controller receives 25 pulses. Now i need to test this received bit stream to see if it is equal to a constant value stored in the code. If they matches i would toggle an output pin.
Can someone throw some quick code to do this ..??
Thankzz & Bye
-Steve
