Hi all iam working c8051f020 ,iam new to microcontroller field , In assembly we specify org 0000h , but how it can be specified in keil c why bcos as soon as iam doing single stepping my programme the control is jumping to 0FA2H,instead of 0000h how can i run programme from 0000h in C(keil c) kidnly provide some solution regards james
The 8051 hardware will ALWAYS begin execution at address 0x0000 - that's the way the hardware works. When you write in 'C', it will place code at 0x0000 to jump to the startup code in startup.a51 - see the C51 Manual for details. When it's finished, startup.a51 jumps to Keil's runtime startup code - and it is this startup code that eventually calls your main() function. Thus you can see that "run programme from 0000h in C(keil c)" is actually meaningless.
hi neil thanks for your valuable reply . regards james d
