Hi all iam working c8051f020 ,iam new to microcontroller field , In assembly we specify org 0000h , but how it can be specified in keil c why bcos as soon as iam doing single stepping my programme the control is jumping to 0FA2H,instead of 0000h how can i run programme from 0000h in C(keil c) kidnly provide some solution regards james
hi neil thanks for your valuable reply . regards james d
The 8051 hardware will ALWAYS begin execution at address 0x0000 - that's the way the hardware works. When you write in 'C', it will place code at 0x0000 to jump to the startup code in startup.a51 - see the C51 Manual for details. When it's finished, startup.a51 jumps to Keil's runtime startup code - and it is this startup code that eventually calls your main() function. Thus you can see that "run programme from 0000h in C(keil c)" is actually meaningless.
