I'm having serious problem with the following code:
unsigned char code * Progtxtstring_ENG[] = { "PROGRAM", "SYSTEM" }; unsigned char code * pMenu; //User selected English pMenu = Progtxtstring_ENG; //Why doesn't this work, it just get garbage out: printf("%s",pMenu[0]); // This line below works printf("%s",Progtxtstring_SWE[0])
Progtxtstring_ENG is an array of pointers; pMenu is just a single pointer. What do you need to do if you want to extract a single element from an array...?
I want to use the pMenu just as I use the Progtxtstring_ENG. I want to switch between arrays of pointers so I can point to different language. Maybe this will explain better:
unsigned char code * Progtxtstring_SWE[] = { "Program", "Tank tryck" }; unsigned char code * Progtxtstring_ENG[] = { "Program", "Tank Pressure" }; //I want an pointer to the array of pointers unsigned char code * pMenu; //User selected Swedish. (Not shown) pMenu = Progtxtstring_SWE; // Here I'm trying to print "Tank Tryck" printf("%s",pMenu[1]); // This line Prints "Tank Tryck" printf("%s",Progtxtstring_SWE[1])
Hmmmm I guess I need an char **ptr to access the array of pointers. It's clearing up a bit...
perhaps re-writing the definitions very slightly might help:
char *pChar
char* pChar
"I want to use the pMenu just as I use the Progtxtstring_ENG. I want to switch between arrays of pointers so I can point to different language." Why confuse yourself with an extra pointer, then? Why not just use a 2-dimensional array?
Why not just use a 2-dimensional array? Because true 2-dimensional arrays essentially don't exist in C? You can define arrays-of-arrays, sure, by you can't do very much with them that wouldn't silently turn them into a pointer-to-array. Or because he would need a dynamic array for this to work, with more than one unknown dimensions, found in some other place than the outer-most indexing level:
char string_table[n_tables][/*unknown*/][/*unknown*/]
"Or because he would need a dynamic array for this to work" Really? I'd assumed there'd be a fixed number of languages, and a fixed number of entries in each menu - especially as he's storing them in code space:
char menu[NUM_LANGUAGES][NUM_ENTRIES]
