Hi all! i am working on a project where i need to control an external ADC chip with an unusual SPI interface. in other risks (and other compilers) i did this with inline assembly succesfully. With UV2 it seems not to work so well...NOT AT ALL ACTUALLY! I suppose it is my fault, but i decided to create a library file for this purpose, as a driver for the ADC. there is only one simple function to implement , which refreshes the ADC with new value.i prefer to use assembly language for this purpose. i have written the asm code and the ADC.A51 file is ready and assembled succesfully. now i need some help on how to turn this into a library...actually i need a detailed description cause i seem to have trouble with basics.i use the output options to tell UV2 to turn my file into a lib file , and so it does.but i guess i need some init code to include in my asm file and a header file. so questions: 1.what else do i need to include/declare in my asm file so that the file is ready to be used for library? 2. how to create a header file? ............IN OTHER WORDS I NEED A STEP BY STEP TUTORIAL on how to create a lib (from my asm subroutine) FROM SCRATCH! thanx in advance Alex
step 1 Create a module with dummy C function ralph.c with the parametres and return you want from your assembly function. step 2 cut the generated assembly and save it as Ralph.a51. step3 add you code to ralph.a51. step4 assemble ralph.a51 Erik
Hi, thank you for your answer. I've read this "recipie" before , but i suppose this wom't create a lib. Am i right?
but i suppose this wom't create a lib no, but this will
if not exist as.lib goto usliex del as.lib :usliex c:\keil\c51\bin\lib51 c as.lib >..\trash\trashbin c:\keil\c51\bin\lib51 a avmain.obj to as.lib >..\trash\trashbin
Now you confused me! I am not a C or Compiler expert. I used to write code in assembly all these years.i bet you are right but a novice like moi....can't handle all this. what i did just now is the following: i started a new project with my_lib.c file as source with my_func as the fuction that implements the code to be compiled to library and using the #pragma asm i added assembly code in there , using R7 and R5 to pass variables to asm code.then i configured OUTPUT to create a lib instead of exe and compiled.my_lib was created. can i use this now , or do i have to create a header file?(if yes how????) Thanks again
PLEASE rewrite your post - separate and number the questions. e.g. what does #pragma asm i added have to do with a library? btw why on earth do you use >#pragma asm instead of just making a .a51 file? Erik
Hi I used #pragma asm because i wanted to add my asm routine inside the function that I wrote. I read some other open source libraries and saw some mixed-langauge implementations of lib-source. actually i thought that writting a C function with inline assembly and compiling it to Lib is the best way.here is what i did:
#pragma SRC unsigned char Dac8801 (unsigned char val,unsigned char chan) { if (chan>7) return(0); #pragma asm mov A,R0 push ACC mov A,#0x07 ORL P2,#00000111B clr P2.0 ;clr CS mov A,R7 ;load dac_no to A RR A RR A RR A mov R0,#3 loop1: RLC A MOV P2.2,C clr P2.1 ;clr CLK setb P2.1 ;set CLK DJNZ R0,loop1 mov A,R5 ;load dac_data to A mov R0,#8 loop2: RLC A MOV P2.2,C clr P2.1 ;clr CLK setb P2.1 ;set CLK DJNZ R0,loop2 pop ACC mov R0,A setb P2.0 #pragma endasm return(1); }
actually i thought that writting a C function with inline assembly and compiling it to Lib is the best way You can not "compile to lib" you can only "compile to obj" THEN you can put the object in a library. 1) is this a good start? 2) what does it take to make ports and pins be defined outside the library 3) if all is good , how do I write a header file for this? 1) sure, you need code before you can put it in a library; however I still would recommend a pure assembler module. 2) you can't - SFRs are absolute addresses and used at COMPILE time. 3) just as for any other module Erik
I am afraid i am being a pain in the ... Anyway you assume that i know how to "write" a header file , but i don't! would it be easier if you gave me an example file for lib and header? the features i need is to pass 2 unsigned char to it and control 3 I/O pins inside my function. my code is in assebly as you already know. i saw a lib that expects a definition of port and pin addresses before including the lib so that the lib "knows" from definition which ports to use. for example a clock pin and a data pin for soft-SPI lib would ask for a definition (inside main source) like:
#define SWSPI_PORT 0x20 // soft-SPI port address #define CLK 0 //clock pin number #define SDI 1 // SDI (data) pin number
would it be easier if you gave me an example file for lib and header? there is tons of examples right here at the Keil site and the below, actually, is an extract from a .h file. #define SWSPI_PORT 0x20 // soft-SPI port address #define CLK 0 //clock pin number #define SDI 1 // SDI (data) pin number which would tell the compiler that the library function when refering to CLK , means P1.0,SDI means P1.1 That works, but require "presence at compile time" which you can not have for a library. Erik
2) you can't - SFRs are absolute addresses and used at COMPILE time. Actually, you can. It's just a little tricky and isn't recommended for novices. http://www.keil.com/support/docs/2413.htm Jon
step 1: create .obj files c51 file.c will create file.obj step 2: create .lib files l51 create file.lib and u can find some more commands in http://www.keil.com/support/man/docs/lib51/lib51_commands.htm.
